How to open attachment in same window through lotus script
hi i will try to open attachment file through lotus script code is–>>
Dim s As New NotesSession
Dim db As NotesDatabase
Dim v As NotesView
Dim entry As NotesViewEntry
Set db=s.CurrentDatabase
Set v=db.GetView("imageEntry")
Set entry=v.GetEntryByKey("1")
If Not entry Is Nothing Then
	value=entry.ColumnValues(1)
	v1=Strleftback(value,"'ta")
	v2=Strrightback(v1,"'/")
	v3="http://144.0.24.211/"+v2
	Print | <script>window.open("|+v3+|")</script>|
	Print |<META HTTP-EQUIV="Refresh" CONTENT="1; URL=JavaScript:history.go(-1)">|
Else
	Print | <script>alert("|+ "File doesnot exist" +|")</script>|
But this code is working fine and attachment will be open in another window but i want to open this attachment in same window.This window.open code will be open attachment in another window how to open this in same window
pls guide me
amar
Subject: how to open attachment in same window through lotus script
window.open is suppose to open another window.
so replace
window.open(“your URL”)
with
location.href = “your URL”
Ashish
Dim db As NotesDatabaseDim v As NotesView
Set v=db.GetView(“imageEntry”)
Set entry=v.GetEntryByKey(“1”)
v1=Strleftback(value,“'ta”)
v2=Strrightback(v1,“'/”)
v3=“http://144.0.24.211/”+v2
Print {
  <script>location.href="}&v3&{";
  </script>}
Use this and let me know
RIshi
Hi Amar, How are u.Can U send ur Req Clearly.
my id is :- pawan.kumar@v2solutions.com
PAwan
