How to mark a document as read when opened in a preview pane?
Hello,
I want to mark a document as read when it’s displayed in the preview pane. I haven’t been able to find anything in the help.
Thanks,
Brandon.
Subject: How to mark a document as read when opened in a preview pane?
file - preferences - user preferences / under advanced options,- should be the firts option
Subject: File, Preferences, User Preferences, Basics…
Additional Options, Mark documents read when opened in preview pane.
Subject: From The Help File
To mark documents as already read when you preview them
  1. From the menu, choose File - Preferences - User Preferences.
Macintosh OS X users: Notes - Preferences - User Preferences.
  1. Under Additional Options, select “Mark documents read when opened in preview pane.”
  2. Click OK.
See Also
Basic preferences
Putting views to work
Panes: windows into Notes
Previewing documents
