How to increment a field value using Lotus script on web
How to increment a field value using Lotus script on web ?
i am using x as a number field which is editable and has default value
temp:=@Max(@DbLookup(“”:“”;“”:“”;“sessiontest”;@Name([CN];@UserName);2));
@If(@IsError(temp);0;temp)
once the value is incremented i want to check on web on click of button whether the field x contains 7 and then using lotus script i want a msg box saying “competed”.
Pls suggest
Subject: How to increment a field value using Lotus script on web
I suggest that you create an agent with your logic and invoke this agent from the button. The NotesSession.DocumentContext refers to the current document.
