i use a button for editing the field in web and I have used @command (editdocument)but it is editing whole document instead of one field so how I give the restriction for one field
Subject: how to give edit authority of perticular section in web
Please add that field into Controlled Section and in the second tab of Controlled section properties, you can write a formula to compute the persons name who should be able to edit that section. No need to provide a button if you make a scetion as controlled section.
Let me know if you require any more information,
-Vinay
Subject: RE: how to give edit authority of perticular section in web
thanks vinay for your response but i donn’t think that control section work in web.and without use of edit button how can i make save document as edit mode in web.if there is any alternative please respond me
thanks & regard
Rupesh
Rupesh,
Create a section in DHTML and keep inside
Cheers
Rishi.
