I have a form with a embedded view in that when i select some documents and click a button whichis on that form, I am calling a agent which will display the field values of a selected documents.
The agent I have written in a Lotus Script.
Everything is working properly but Problem with the ListBox field values. Its displaying only the first Item in a list box. I am pasting my code, In that “Proj_Team” is a ListBox.
How do I display all the elements in a ListBox?
Here is the code
Sub Initialize
Dim docSubmit As NotesDocument
Dim varDocUNID As Variant
Dim docSelected As NotesDocument
Dim total As Double
Dim Total_GRA As Double
Dim Total_GRB As Double
Dim Total_GRC As Double
Dim db As NotesDatabase
Dim arrsize As Integer
total = 0
'Get the document that was submitted with the embedded form
Set docSubmit = session.DocumentContext
Set db = docSubmit.ParentDatabase
Print " <HEAD>"
Print | </HEAD>|
Print |<BODY onload="window.print()">|
'Setup the web page's font
Print |<Font Face="Verdana" size="2">|
’ Print ||
Print "<H3><center>Product/Project Billings</center></H3>"
'Get the field that contains the UNID’s of the selected documents (array)
varDocUNID = docSubmit.GetItemValue("$$SelectDoc")
'Make sure that at least one document was selected
If varDocUNID(0) = "" And Ubound(varDocUNID) = 0 Then
Print "No documents were selected.<BR>"
Else
'Print "The customer orders you selected were: "
'Print"<BR>"border: solid 1px darkgreen
Print | <TABLE border=".5" bordercolorlight="#000000" align="center" width="100%" cellpadding="5">|
Print |<TR>|
Print |<TH bgcolor="#F3F3F3"><font face="Verdana" size="1">Bill Month</font></TH>|
Print |<TH bgcolor="#F3F3F3"><font face="Verdana" size="1">Project Name</font></TH>|
Print |<TH bgcolor="#F3F3F3"><font face="Verdana" size="1">Team</font></TH>|
Print |<TH bgcolor="#F3F3F3"><font face="Verdana" size="1">Activity</font></TH>|
Print |<TH bgcolor="#F3F3F3"><font face="Verdana" size="1">GR A</font></TH>|
Print |<TH bgcolor="#F3F3F3"><font face="Verdana" size="1">GR B</font></TH>|
Print |<TH bgcolor="#F3F3F3"><font face="Verdana" size="1">GR C</font></TH>|
Print |<TH bgcolor="#F3F3F3"><font face="Verdana" size="1">Total Effort</font></TH>|
Print |</TR>|
'Loop through all the documents that were selected
Forall unid In varDocUNID
Set docSelected = db.GetDocumentByUNID(unid)
If Not docSelected Is Nothing Then
Print|<TR><TD bgcolor="#EAF2FF"><font face="Verdana" size="1">| & docSelected.Bill_Month(0) & " - " & docSelected.From_Date(0) |</font></TD>|
Print |<TD bgcolor="#EAF2FF"><font face="Verdana" size="1">| & docSelected.Project_Name(0) & |</font></TD>|
Print |<TD bgcolor="#EAF2FF"><font face="Verdana" size="1">| & docSelected.Proj_Team(0)& |</font></TD>|
Print |<TD bgcolor="#EAF2FF" align="center"><font face="Verdana" size="1">| & docSelected.Activity(0) & |</font></TD>|
Print |<TD bgcolor="#EAF2FF" align="center"><font face="Verdana" size="1">| & docSelected.GradeA(0) & |</font></TD>|
Print |<TD bgcolor="#EAF2FF" align="center" ><font face="Verdana" size="1">| & docSelected.GradeB(0) & |</font></TD>|
Print |<TD bgcolor="#EAF2FF" align="center"><font face="Verdana" size="1">| & docSelected.GradeC(0) & |</font></TD>|
Print |<TD bgcolor="#EAF2FF" align="center"><font face="Verdana" size="1">| & docSelected.GradeA(0) + docSelected.GradeB(0) +docSelected.GradeC(0) & |</font></TD>|
'total = total + docSelected.OrderTotal(0)
Total_GRA=Total_GRA+docSelected.GradeA(0)
Total_GRB=Total_GRB+docSelected.GradeB(0)
Total_GRC=Total_GRC+docSelected.GradeC(0)
total = Total_GRA+Total_GRB+Total_GRC
End Forall
Print "</TABLE>"
Print "</BODY>"
'Print the total of the selected orders
Print "<BR><BR>"
'Print "Total of the orders selected was " & Format(total,"Currency")
Print "Total PM effort for Grade A : " & Total_GRA & "<BR>"'Format(total,"Currency")
Print "Total PM effort for Grade B : " & Total_GRB & "<BR>" 'Format(total,"Currency")
Print "Total PM effort for Grade C : " & Total_GRC & "<BR>"'Format(total,"Currency")
Print "Grand Total (PM) : " & total
'Add a button to return to the view
Print "<BR><BR><BR><BR><BR>"
'Print |<Center><input type="button" value="Return to view" onClick="history.back();"></Center>|
Print "<BR><BR>"
Print| (Signature) |
Print "<BR><BR>"
Print | Project Manager |
Print "<BR>"
Print | Date : |
Print |</Font>|
Am I doing something wrong in - Print || & docSelected.Proj_Team(0)& ||
Thanks for your suggestions inadvance
regards
Sanjay
