How to disable Client Side Caching for a specific web page?
Greetings,
I have a specific web application that I need to disable client side caching for some real time reporting (using a $$ViewTemplate form).
Is there a way to do this on the domino server?
For ASP.Net, I have found that you can use the following. Can it be translated for our apps?:
<%@ OutputCache Location=“None” VaryByParam=“None” %>
To disable client side caching programmatically:
protected void Page_Load(object sender, EventArgs e)
    Response.Cache.SetCacheability(HttpCacheability.NoCache);
