How to adjust iNotes idle session timeout?
Most of the documentation I see on this involves changing something in the section of the server document marked
This section does not apply as “Load internet configurations from Server\Internet Sites documents” has been enabled.
So, if you are doing internet sites documents how do you adjust that?
Subject: Web SSO Configuration?
It’s been awhile since I’ve played with this - but as I recall if your Session Authentication is set to ‘Single Server’, it’s specified directly below that on the Internet Sites Document.
If your Internet Sites document is set to Multiple Servers (SSO) it is specified on the Web SSO configuration document.
Subject: Thanks
We have found it. We have determined that it’s already high enough, unless they need more than 90 minutes.
Apparently it’s nothing to set your watch by. I had it last 2 hours, with less than 1 minute ±
