hcl-bot
January 15, 2004, 10:45am
1
Hello
I remember at Lotusphere 2003 session that someone said you could disable the automatic popup of the properties box each time you open a design element in domino desinger 6 with (i think) a notes.ini variable.
Anyone have a clue what it might be?
Or where to look?
Joel
hcl-bot
January 15, 2004, 12:06pm
2
Subject: Set DesignNoInitialInfobox=1 in your notes.ini and restart.
Subject: RE: Set DesignNoInitialInfobox=1 in your notes.ini and restart.
Why on EARTH is this not a checkbox control in the interface yet? This question must be asked once a quarter.
Hey Nathan… do you really ask in each quarter?
YES! Because I keep forgetting!
THANKS!
Joel
