Hide When Formula problem
I have 2 fields …Field A and Field B. They are both in separate tables. When Field A is = to “NO” I want field B to automaticaly appear before the document is saved. Anyone know how to do this ?
Subject: Hide When Formula problem
Use the hide/when formula below on Field B.
FieldA != “NO”
Make sure FieldA has the setting, refresh fields on Keyword change
You have a few ways, but the easiest is @Command([RefreshHideFormulas]) or the NotesUIDocument.RefreshHideFormulas method in LotusScript, which is one of the few ways to get the rich text to change without closing and opening the document. You have to find a way to trigger the command, perhaps on the exiting event on Field A. Of course, if this is a keyword field, you can just set it to refresh when changed, which will also work.
