good evening! for the past couple of weeks i have been working on trying to get our employee application online. being that this application has over 100 fields… i need to break it up into sections. i have about 5 or 6 sections with the last section having the final submit. the problem i am having is with the hide whens on the sections. i have tried using id tags and setting the display from block to none in javascript and each time i hit a combobox that refreshes fields… i get sent all the way back to the 1st section of the app. i then tried using a flag field and set it in section with a continue button, but when i submit the form, all the fields except the last section are blank. can someone please help me figure how i next to seperate this app into sections? below are the methods i have tried.
method 1
fields for section here
button code
document.getElementById(‘A’).style.display=‘none’;
document.getElementById(‘B’).style.display=‘block’;
method 2
hide each section depending on AppStatus field (example: “A” “B” “C”) - starts out as “A”
button code
window.document.forms[0].AppStatus.value=“B”
_doClick(‘$Refresh’, this, ‘_self’, ‘AppStatus’)
