| This thread was migrated from an old forum. It may contain information that are no longer valid. For further assistance, please post a new question or open a support ticket from the Customer Support portal. |
1. Is it possible to create individual components in Sketch and not whole forms?
2. If I modify a previously exported component on Sketch and I re-import it, is the business logic lost?
3. Is it possible to import a Kony component into Sketch and modify it and then reimport it later?
Thank you..
1) Is it possible to create individual components in Sketch and not whole forms?
Ans) Yes, you can create it and import it in kony.
2) If I modify a previously exported component on Sketch and I re-import it, is the business logic lost?
Ans) Business logic will not lost, only UI modification will reflect.
3) Is it possible to import a Kony component into Sketch and modify it and then reimport it later?
Ans) No its one way communication from sketch to kony visualizer.
Perfect, thanks.
Just one last thing..
Is there a guide for the first two points?
Thankssss..
