I’m having a problem with my designer client when working on local databases.
when I’m in a database that has documents, and I preview in the web browser they forms look like they’ve working correctly, but anytime I open a view I get “No Documents Found”. When I view the same from the client there ARE documents. I’ve tried this with several local databases. and I’m getting the same thing.
None of the databases are using readers fields of any sort. I’ve even tried giving anonymous Manager access without any luck. Again, everything seems to be working fine, I can even save docs from the browser but just can’t see any.
I’ve upgraded my client to 6.5.4 and no luck. It used to work… it just stopped working for some reason.
Any advice would be appreciated.
Subject: Help with Web Preview - No documents found.
That’s a bug - spr DBRO65HJJ9 - fix checked in 3/30.
The problem is that when previewing locally, there is no names.nsf from which to get some useful defaults, like the default number of documents to display in a view. So it defaults to zero, and you know the rest.
If you put your db up on a server, web preview will work just fine.
-sl
Subject: RE: Help with Web Preview - No documents found.
Thnaks for the response. I’m glad I’m not the only one because it’s been driving me nuts. Until the fix gets in do you know if there’s a workaround? I frequently work disconnect and am starting to do more web apps as opposed to client apps. I know I could install a server on my local machine but I’m not sure about that as I don’t think we have any extra liscenses for that.
Sorry, no workaround that I am aware of - to make it work you have to move your db to a server, or get the 6.0.6/6.5.5 release when it ships.
-sl
I have the same problem on 7.02.Anonymous is set to No Access and Default to Author. The database is on a Domino server.
When authenticated I cannot see my own documents although I can see them in the client.
I use $$ViewTemplateDefault. I used this setup successfully in another web enabled db. I cannot see what is different that stops this from working. I tried re-creating the $$ViewTemplateDefault from scratch hoping this will fix the problem, but to no avail.
