Help with very simple lotusscript
hello, can anyone help me with this script on the notes client. I have a button on a view. I want this button to print all the documents in the view to a different form called “printinvite”. I’m trying to move off forumla language and onto lotusscript but I’m stumped with this problem. As always any help appreciated.
Sub Click(Source As Button)
Dim db As Notesdatabase
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument
Dim view As notesview
Set db =session.currentdatabase
Set uidoc = workspace.CurrentDocument
Set view = db.GetView("everything")
While Not (doc Is Nothing)
	doc.Form="printinvite"
                            call uidoc.print(1)
	Set doc=view.GetNextDocument(doc)
Wend
Subject: help with very simple lotusscript
Thanks so much guys!
Linda
Dim w As New NotesUIWorkspace
Dim s As New NotesSession
Const main_form = "a"
Const print_form = "p"
Set db = s.currentdatabase
Set view = db.GetView("a")
	Call doc.ReplaceItemValue("Form", print_form)
	Call doc.Save(True, True)
	Set uidoc = w.EditDocument(False, doc, True)
	Call uidoc.Print(1, 1, 1)
	Call uidoc.Close
	Call doc.ReplaceItemValue("Form", main_form)
Wend
hope it will help you
Code is simple but problem not. You can print current view or current document by uiview or uidoc. Error is that you try print current uidoc not your doc. Solution should be for first
Set notesUIDocument = notesUIWorkspace.EditDocument( [editMode] , [notesDocument] , [notesDocumentReadOnly] , [documentAnchor$] , [returnNotesUIDocument] , [newInstance] )
and print notesUIDocument
for details how to use EditDocument look at help
