Help with setting values of a listbox dynamically
I have 2 fields on my custom control, a text box and a listbox. The choices for the listbox are to come from the text box (ReqFiles). So, if the user types in “red, blue, green”, then I want those to be 3 choices in the listbox field. I can’t get the listbox choices to compute. Here is my code for the values of the listbox:
if (getComponent(“ReqFiles”) != null)
var reqlist = getComponent(“ReqFiles”).getValue();
if (reqlist == “”)
return("");
else
listarr = reqlist.split(",");
return(listarr);
I’m still new to js, so it may not be the most efficient piece of code - but why won’t it work?
Any ideas?
Thanks,
Bob
