Help with rich text fields
Hello,
I created a submit action button with the formula below. I have a rich text field called RequestDesrp. Before submitting I do check if the field is blank, if field is not blank then submit. My problems is that if I enter a word in the field RequestDesrp a my prompt message will appear. Is there something wrong with my formula…
@If(
RequestDescrp = “” ; @Prompt([Ok]; userError ; " Request Description field can not be blank" );
@Do(
@Command([FileSave]);
@MailSend(SendTo;“”; “”; SubjectText; “” ; Body; [IncludeDoclink]);
@Prompt([Ok]; title; "Service Request # " + @Text(ticket) + " has been submitted ");
@Command([FileCloseWindow])
Subject: help with rich text fields
The document needs to be saved before you can access rt fields. Try this:
@If(@Command([FileSave]);
@Do(
@MailSend(SendTo;“”; “”; SubjectText; “” ; “RequestDescrp”; [IncludeDoclink]);
Note: You may want to change Body in the @Mailsend to RequestDescrp. It must also be in quotes.
To check the RT field is not blank create a new hidden editable field ‘checkrt’ and use its validation event to check the rt field is not blank. The above code will not work if there is a field validation on the form.
