Help with @IsDocBeingSaved
If ONE of this three field have a value a want success, how will a do that…? And where will a put it. Is it ok if a put it in validation on SendTo-field.
@If(@IsDocBeingSaved & SendTo!= “” | CopyTo!=“” | BlindCopyTo!=“”;
@Failure("Select receiver before sending.");
@Success
Kind regards
David
Subject: Field Validation (Was: Help with @IsDocBeingSaved)
Hi David,
Yes - the following formula in the Input Validation for just one of the fields will work:
@If(SendTo = “” & CopyTo = “” & BlindCopyTo = “”; @Failure(“Enter at least one recipient you fool!”; @Success)
Saving will fail if they are all blank.
Validation formula are not the most elegant way of handling field validation though because they are evaluated after the QuerySave event. If you’re doing something fancy in there - perhaps prompting the user for confirmation to proceed it is annoying to the user if, after they’ve said yeah let’s do that, we then tell them they can’t because the form isn’t completed properly.
For each form, I tend to call a customised lotusscript function from QuerySave. The function evaluates to True if the fields are valid and False if they’re not. If False I prevent the save by setting the Continue variant to false.
Here is the QuerySave code:
Sub Querysave(Source As Notesuidocument, Continue As Variant)
'Continue if there are no field validation issues
If fnFieldsValid(Source) = True Then
	Continue = True
Else 'Validation issues
	Continue = False
And the function:
Function fnFieldsValid(Source As NotesUIDocument) As Boolean
Dim s As New NotesSession
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim strShitList As String, strFirstField As String
Dim strMsg As String, strTitle As String
Dim intProceed As Integer, intErrCount as Integer
Set db = s.CurrentDatabase
Set doc = Source.Document
'Assume everything is OK
fnFieldsValid = True
'First Check
If doc.SendTo(0) = "" And doc.CopyTo(0) = "" And doc.BlindCopyTo(0) = "" then
	'No recipient
	intErrCount = intErrCount + 1
	strShitList = strShitList + "(" + Trim(Str(intErrCount)) + ") You must enter at least one name in either the To, cc or bcc fields" + Chr(10) 'Chr(10) = Carriage Return
	If strFirstField = "" then strFirstField = "CopyTo"
	fnFieldsValid = False
End if
'Second Check
If doc.Field4(0) = "" Then
	strShitList = strShitList + "(" + Trim(Str(intErrCount)) + ") You must enter a value for Field4" + Chr(10)
	If strFirstField = "" Then strFirstField = "Field4"
If fnFieldsValid = False Then 'Tell them
	strMsg = "You have not entered one or more required values:" + Chr(10) + Chr(10)
	strMsg = strMsg + strShitList
	strMsg = strMsg + Chr(10)
	strMsg = strMsg + "Your document was NOT saved."
	strTitle = "Required Fields Not Completed"
	Messagebox strMsg, MB_OK + MB_ICONSTOP, strTitle
	'Go to first bad field
	If Not strFirstField = "" Then
		Source.GotoField(strFirstField)
End Function
This is a simplified version if code I use in a live App and haven’t tested it with the changes. I haven’t tested the it since changing it so there may the odd typo.
HTH
