Help with hidden field
Hi;
I have a field on a web based form called ‘draft’ which is set to a value “draft” if the use user wants to submit the form and come back to edit it later.
The field is hidden by setting the HTML attributes to “TYPE="HIDDEN"”.
The button to fire this is
Problem is, I keep getting a javascript error ‘this.form.draft’ is null or not an object…which i think means that my javascript is not seeing the field object.
Anyone know why this is?
Please help…
Subject: Help with hidden field
Ok got it…
had to check generate fields as HTML…
