Help with display view in web
I want to know we can change the default style for view in web because it’s ugly.
How can we add html to format our view ?
thx.
Subject: Help with display view in web
“Treat view contents as HTML” is the view property you should look for under the propeller(last but one) tab of view properties. Then you’ll need to write some HTML in the columns. Here’s a link to a template from sandbox:
http://www-10.lotus.com/ldd/sandbox.nsf/ecc552f1ab6e46e4852568a90055c4cd/ee2cba05affde211852569000049a457?OpenDocument
HTH
Sai
