Hi all,I am trying to bring my IT Orders DB into this century by adding an Add to Basket feature.
I have a large tabbed table of items, with a field called “Amount”, which is an editable number field.
Below this table is a hidden table containing the same information with a field called “Amount1” which is a number field computed for display, with the default value of “Amount”.
I have a hide when formula on each item of hide if “Amount” = “”.
The hide formula works , & if a figure is entered in the amount field the row appears, I have a Add to basket button with the forumla
@Command([RefershHideForumals])
After clicking on the button the “Amount” field is still blank.
I tried changing the “Amount” field into a listbox with a Refresh fields on keyword change, but I’m not keen on these as it is very easy to change the amount by mistake with the scroll on the mouse.
Does anyone have any ideas, I am not familiar with lotus script, hence this long way around.
Happy Holidays to all
Emma
