Function ODBCResultSet.GetValue doesn’t working properly with string.I have Postgresql DB and I want get data from it using SQL query.
Dim connection As New ODBCConnection
Dim query As New ODBCQuery
Dim ResultSet As New ODBCResultSet
Dim v_UserName(10) As Variant
Dim i As Integer
b_Result = connection.ConnectTo(“PostgreSQL30W”)
Set query.Connection = connection
Set ResultSet.Query = query
query.SQL = {SELECT “UserName” FROM “USER_ACTIVITY”}
'//UserName is the column of “USER_ACTIVITY” table and it
'//has character varying data type.
If(ResultSet.IsResultSetAvailable) Then
i = 0
Do
ResultSet.nextrow
v_UserName(i) = ResultSet.GetValue("UserName")
'// GetValue return false
'// ErrorMessage - LS:DO- Cannot convert data from
'//native to expected or requested datatype
Loop Until ResultSet.IsEndOfData
Call connection.Disconnect
'//With columns which have decimal or boolean datatype
'//function GetValue working properly
