Help querying DB2 with LS2J JDBC
Hi everyone :
This is the first time i am trying to use JDBC via LotusScript (LS2J).
I can get connected to a DB2 server, but i’m not sure how to run a query and retrieve the result.
This is the code i am using…
The Java Class :
public class JDAL {
private Connection con = null;
private PreparedStatement st=null;
private ResultSet rs=null;
public ResultSet getData( String query) throws SQLException
	st = con.prepareStatement(query);
	rs = st.executeQuery();
	return rs;
public void openConnection(String server, String database, String port, String user, String pass) throws ClassNotFoundException, SQLException
	String url = "jdbc:db2://"+server+":"+port+"/" + database;
	Class.forName("com.ibm.db2.jcc.DB2Driver");
	con = DriverManager.getConnection(url, user, pass);
public void closeConnection() throws SQLException
	if (rs!= null)
		rs.close();
	if (st!= null)
		st.close();
	if (con!=null)
		con.close();
The LS code :
UseLSX “*javacon”
Use “com.iga.dal”
Dim jSession As JAVASESSION
Dim jClass As JAVACLASS
Dim jObject As JavaObject
Dim rsClass As Javaclass
Dim rsObject As Javaobject
Set s = New notessession
Set db = s.CurrentDatabase
Set docProfile = db.GetProfileDocument("ProfSetup")
Set jSession = New Javasession
Set jClass = jSession.GetClass("JDAL")
Set jObject = jClass.CreateObject
Dim docCli As NotesDocument
If docProfile Is Nothing Then
	Msgbox "No se encuentra el documento de configuración", 64, title$
	Exit Sub
'Conecta al Host
Print "CargaClientesPeru : Conectando a CLIENTES"
Call jObject.openConnection(docProfile.ClientesServer(0), docProfile.ClientesDatabase(0), docProfile.ClientesPort(0), docProfile.ClientesUser(0), docProfile.ClientesClave(0))
SQL$ = { select CUSTNUM, ABREVNAM, TAXNUM } + _
{ from CROS_CROVPMN } +_
{ where CTYNUM = '815' }
Set tRes = jObject.getData(SQL$)
call jObject.CloseConnection()
Exit sub
the jObject IS getting connected to the db2 server; the query is correct as i have tested in the db2 client.
What i am not sure how to do is, to run the query, and then read the result line by line.
Any help will be appreciated.
