Hi all,
I’ve been having numerous problems with sending an e-mail via my Lotus Notes database using ASP.Net referencing the Domino DLL and was hoping someone could help me figure out why I keep getting the message “could not open the ID file”
My Settings
Notes.ini is located in c:\documents and settings\nwalsh\Local Settings\Application Data\Lotus\Notes\Data
nwalsh.id is also located here with KeyFilename=nwalsh.id
My Code
Public Sub TestNotesAccess()
Dim NotesSession As Domino.NotesSession
Dim NotesDirectory As Domino.NotesDbDirectory
Dim NotesDatabase As Domino.NotesDatabase
Try
Response.Write("Mail Server: " & ConfigurationSettings.AppSettings("MailDirectory") & "<br>")
Response.Write("Mail Database: " & ConfigurationSettings.AppSettings("MailDatabase") & "<br>")
Response.Write("Mail Password: " & ConfigurationSettings.AppSettings("MailPassword") & "<br />")
NotesSession = New Domino.NotesSession
Response.Write("NotesSession Created<br>")
NotesSession.Initialize(ConfigurationSettings.AppSettings("MailPassword"))
Response.Write("NotesSession Initialized<br>")
NotesDirectory = NotesSession.GetDbDirectory(ConfigurationSettings.AppSettings("MailDirectory"))
Response.Write("NotesDirectory Successful<br>")
NotesDatabase = NotesDirectory.OpenDatabase(ConfigurationSettings.AppSettings("MailDatabase"), True)
Response.Write("NotesDatabase Selected<br>")
If NotesDatabase.IsOpen Then
Response.Write("Lotus Notes Successfully Accessed.<br>")
Response.Write("Using Mail File: " & NotesDatabase.Title & "<br>")
Catch ex As Exception
Response.Write("An error happened.<br>")
Response.Write(ex.Message & ("<br>"))
Response.Write(ex.Source & ("<br>"))
Finally
'Clean Up!
NotesDatabase = Nothing
NotesDirectory = Nothing
NotesSession = Nothing
End Try
My Output & Error
Mail Server: NAUNB219
Mail Database: mail\nwalsh.nsf
Mail Password: test1234
An error happened.
Notes error: Could not open the ID file
NotesSession
Other Factors
There’s another notes.ini file located under C:\Documents and Settings\MBKW053661\ASPNET\Local Settings\Application Data\Lotus\Notes\Data
I have a reference in my path to c:\documents and settings\nwalsh\Local Settings\Application Data\Lotus\Notes\Data
I have given the ASPNET machine account access to the notes.ini file under c:\d&s\nwalsh\etc…
So, anyone got any ideas or know of a step by step guide to getting this going on a machine? I’ve been having too many problems which I think may have something to do with the fact that my notes is a multi-user install
