Hello,I will be Very Thankful for you for your kind advice.
Actully i have to implement a function which returns a FT search result in a view(wants to find document in attachments also) or a folder. where end user put a number or string like 10 digit number and click search button and it will display all search result in a view or a folder. I will be very thankfull to you if you please send some RELATED CODE for this problem.
I NEED TO IMPLEMENT THIS FOR A WEB CLIENT ON R5 VERSION.
PLEASE SEND SOME SAMPLE CODE OR RELATED ONE.
THANKS A LOT…
