Help on calendar entry
I’m using a form in a call logging db I’ve created from which the person logging the call can book an Appointment into his/her calendar. Now I would like to make some changes, so the person logging the call could select a person (person X) in a dialog list field and create the Appointment into the calendar of person X.I’ve tried a couple of things, but get stuck everytime. This is the code I use to create the appointment into their own calendar. What needs to be changed to log into person X’s calendar?
Sub Click(Source As Button)
Dim db As New NotesDatabase ("","")
Dim thisUIdoc As NotesUIDocument
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument
Dim userName As New notesname(session.username)
Dim dbfilename As String
Dim dbserver As String
Dim value As Integer
Call db.OpenMail
dbfilename=db.filepath
dbserver = db.server
Set thisUIdoc = ws.CurrentDocument
subject1 = thisUIdoc.FieldGetText("bookingtype")
subject2 = thisUIdoc.FieldGetText("bookingstatus")
subject3 = thisUIdoc.FieldGetText("Serial")
subject4 = thisUIdoc.FieldGetText("Customer")
location1 = thisUIdoc.FieldGetText("Customer")
location2 = thisUIdoc.FieldGetText("Name")
location3 = thisUIdoc.FieldGetText("Address")
location4 = thisUIdoc.FieldGetText("City")
location5 = thisUIdoc.FieldGetText("Country")
todaydate = thisUIdoc.FieldGetText("Now")
Set uidoc = ws.ComposeDocument (dbserver,dbfilename,"Appointment")
Call uidoc.FieldClear("AppointmentType")
Call uidoc.FieldSetText("AppointmentType","0")
Call uidoc.Refresh
Call uidoc.FieldSetText("Subject",subject1 + " -- " + subject2+ " -- " +subject3+ " -- " +subject4)
Call uidoc.FieldSetText("Location",location1+ ",  " + location2 +" -- " +location3+ " -- " +location4+ " -- " +location5)
Call uidoc.FieldsetText("StartTime","08:00:00 AM")
Call uidoc.FieldsetText("EndTime","06:00:00 PM")
Call uidoc.FieldsetText("StartDate",todaydate)
Call uidoc.FieldsetText("EndDate",todaydate)
Subject: help on calendar entry
Does the user invoking the agent have the rights to create an entry in person X’s calendar? if not, maybe you need to have the agent running on behalf of an entity that does.
Subject: RE: help on calendar entry
Within 1 team all calendars are open to each other so this should be no problem
Assuming the user who presses the button has access to add to the other person’s calendar, you would need to locate the mail file of the target user. This could be done using @NameLookup via Evaluate, or by programming the address book view lookup yourself in LotusScript. In the latter case, remember there may be multiple directories; use AddressBooks property to get the list. To see what fields contain the mail server and filepath, find a person document and look at its properties from a view.
Once you have the server and filepath, proceed as you are now doing.
