Help Noted freezing up
We have upgraded to notes 6. When users are in Lotus 123 and have Notes open at the same time (for email)notes freezes everything up and the user is forced to shut it. When this same issue came up on R5 there was an .EXE on the R5 CD that fixed the problem. No such thing on notes 6 CD. Any help to have them both run along side each other would merrit a beer form me. Hope you can help. Thanks!! John
Subject: help Noted freezing up
You’ll need that SmartSuite patch from your R5 CD. For whatever reason they didn’t include it with ND6 so we’ve been using the patch from the R5 CD. Works great!
