HELP: Change Full-Text Index location
Hi all
Is there a way to tell to the Domino Server to create the ft folders with indexes in a different location ?
Thank you very much
RPM
Subject: HELP: Change Full-Text Index location
No there is not because *.ft is always created in the same directory as the database which owns it, butyou may locate your data directory on different place , or
create directory links so you can have some databases on different disks. For the later look in admin help
