Help! Admin mistake correction advice needed
One of our foreign admins apparently selected all last names in the DD starting with Wood – rather than selecting the one person named Wood – and deleted them all. They realized they had made a mistake and copied the other names back in from an address book copy.
However, adminp has been following their requests for each of the other "Wood"s for the last two days and we are just now discovering the fallout.
Question: Since Adminp has removed the names from person documents, unread lists, acls, design elements and reader/author fields – how can I go back and fix the screwup in unread lists, reader/author fields? I have alread added them back to the ACLs of their mail files.
Subject: Help! Admin mistake correction advice needed
there is no UnDo feature of AdminP so it would be a manual process and you may not be able to UnDo everything without major pain. For instance, to UnDo the Reader/Author fields, Unread Lists and Design Elements you’d need to restore any databases that were affected. Pretty painful mistake.
