I’m a VB programmer and I want to open the To Do List in iNotes based on a specific category.
If I use the following in VB:
Call Shell(“C:\Program Files\Internet Explorer\iexplore http://domino/mail/cwalters.nsf/iNotes/ToDo/?OpenDocument”, vbNormalFocus)
and execute it from an action button it works fine.
What i’m looking for is to also include the category some thing like:
http://domino/mail/cwalters.nsf/iNotes/ToDo/?OpenDocument&Categories=“MySpecificCategory”
is something like this possible ??
Subject: Help a VB-programmer with iNotes
Yeah, it’s almost identical in LS:
%INCLUDE “lsconst.lss”
Sub Initialize
MySpecificCategory = "Fun Stuff"
x=Shell("C:\Program Files\Internet Explorer\iexplore http://domino/mail/cwalters.nsf/iNotes/ToDo/?OpenDocument&Categories=" & MySpecificCategory, SHELL_NORMAL_FOCUS)
Subject: RE: Help a VB-programmer with iNotes
Hi Mika,
Thanks for your response.
I think I wasn’t clear enough.
I didn’t mean “is this possible in LS”, I meant “is this possible using VB in a Visual Basic program”.
It seams that iNotes doesn’t accept my
“&Categories=” part of the statement.
Does the whole command line work when you do it from DOS?The question is that if your iNotes is capable of understanding the &Categories syntax, or is it a problem with the string you pass to the VB Shell command.
