I Got a message in my log.nsf
…marked database ‘XXXX.nsf’ for deletion…
How could I slove this problem ?
such as as a comand line or another way?
please tell me , thanks !
Subject: RE: HELP…! A hacker marked my nsf deledtion…
I don’t know whether there’s a way to “unmark” a database for deletion, but don’t exit the database before you make a copy of it, because it will be permanently deleted. Unless you have a replica somewhere?
That is a good advice.thank you.
So is making sure that end-users do not have Manager access to any server-based databases (which they need in order to delete a database – so your “hacker” was somebody to whom you gave permission).
