Hello,
I've a recurent problem with client 11.0.1
After some days, my local replication just stops working. It starts at the launch of the Notes client, but then, it stops. On the Replication & Sync page, I can see "next replication is at...", but it will never start anymore.
The "Start" button has no action neither...
Only solution is to kill everything with the Tasks manager.
Any idea why this happend ?
Thanks.
What is the Location document you are using? Maybe you switched from default Online to some other...
Please check Online location -> Replication tab. Is there a schedule enabled?
Are you replicating your mail file or some 3rd party app? ReplicaID match on server/local?
What is written in log.nsf -> Replication Events?
Are you able to open your database on server (Notes -> Workspace -> Right click on your db name -> Open Replica -> %your server name%)?
I'm using a "local" location doc with a scheduled replication.
It's working because when I launch my Notes client, it starts. Then it will do the next one as well (15 min later), and then it's finished...
Nothing special in the log. No error.
I'm replicating mail file + 3rd party CRM app.
And yes, I can open everything in local and on server.
Every replica on local are ODS 53.
Are you sure you're using 11.0.1PF2? I didn't think that was available yet.
Yeah sorry, my mistake, it's FP1
