Clicking DETAILS reveals the full message:
An internal error occurred during: “getContent”.
nlsxbe (Library is already loaded in another ClassLoader)
Regards, John M
Regards, John M
Subject: VoiceRite Client v3 Plug-In
The errors started after installation of the subject plug-in. I have subsequently disabled the plug-in components and the errors have stopped, so it seems likely that there is compatibility issue.
Regards, John M
How do you disable this plug-in? Thanks
