I have a script sequence that creates an ndl file that mimics the Notes doclink function in Exchange. Within the code there is a call to a function that I am having problems with. The script creates the ndl called fileName$, and the function passes the fileName$ to the email with the following call statement:
Call ‘function name’ (db, doc, fileName$)
I’m having problems building the parameters needed for the function and anyhelp would be greatly appreciated. Thanks.
