French accents problem in view columns when accessed via webmail ( Domino Web Access )
A small problem when our users try to reach their mail via webmail (Domino Web Access):
The accents are replaced by invalid characters in the view columns of the views.
example:
Accès
becomes
AccC(s
As it seems to be good in the content of the document itself, could it be a bug in the iNotes template?
Or is it an invalid server parameter?
Code Page?
Character-set?
Thank you by advance for your help
Philippe Pierlot
Lotus Domino Designer
Belgium
Subject: French accents problem in view columns when accessed via webmail ( Domino Web Access )
Hello,
I experience time to time the same trouble. This can be overcome by changing the charset encoding manually from the navigator.
Not a nice solution but It works.
Regards.
AD
Subject: RE: French accents problem in view columns when accessed via webmail ( Domino Web Access )
hi
according to my experiences, UTF-8 is most of the times a good solution.
Hi Yannick(for the second time today as I already replied a few minutes ago to your reply to another of my posts.)
Unfortunately, I can’t make it work. Even if I change in the browser the encoding to unicode, it doesn’t work.
Maybe the ‘default font’ has to be changed to a unicode one.
(I already had to do this to be able to read chinese characters via the Lotus Notes client).
But I don’t know if such a setting exists for web access…
Meanwhile, I discovered that the error didn’t occur for a replica of my mailbox on another server.
Server settings for domino web engine seems altough be equal on both servers (encoding parameters) but maybe a different level of server (different fix pack) can cause this problem…
As it is not a ‘emergency problem’, I’ll check all the parameters when I’ll have a bit more time…
Thank you for your help,
Philippe Pierlot
Lotus Domino Administrator
Belgium
