FieldGetText("Body") does not return content in Reply With History Body Field
This command not shows the content of the history. How can I do?. I have prove with this: Dim doc As NotesDocument
Dim item As NotesItem
Dim BdyText As String
Set doc = Source.Document
Set item = doc.getfirstitem(“Body”)
BdyText = item.Text
but only shows the first line, not all the history
Subject: FieldGetText(“Body”) does not return content in Reply With History Body Field
Chances are body is a rich text field, which is a different class to an item. code you’ll need is along the lines of …
Dim rti As NotesRichTextItem
Set rti = doc.GetFirstItem(“Body”)
text$ = = rti.GetUnformattedText()
HTH
James
Subject: RE: FieldGetText(“Body”) does not return content in Reply With History Body Field
Only one more thing. When I insert this code on Querysend event text variable is not set
Dim BdyText,text As String
BdyText = text
text = rti.GetUnformattedText()
If Instr(text,“Este mensaje está dirigido únicamente a su destinatario”) = 0 And Instr(text," La Fundación Tripartita para la Formación en el Empleo no asume responsabilidad") = 0 Then
Call cMemoObject.AñadirPoliticaEmpresa()
Set rti = doc.GetFirstItem("Body")
Set item = doc.getfirstitem("Body")
BdyText = text
If Instr(text,"Este mensaje está dirigido únicamente a su destinatario") = 0 And Instr(text," La Fundación Tripartita para la Formación en el Empleo no asume responsabilidad") = 0 Then
