Hello,
I have form which has a field1, DialogList with following formula. “Referesh…” from Field Property is checked. This is a web based application.
a := OrderType;
b := @DbLookup(“Notes” : “NoCache” ; @Subset(@DbName ; 1) : “db1.nsf” ; “(Lookup)” ; a ; 2);
c := @If(!@IsError(a) & !@IsError(b) ; b ; “Select Order Type First”);
" — Select Unit — " : c
This formula works fine for all other values, but only one for value1 whenever users makes a selection, the document gets
refereshed and user sees, " — Select Unit — "+list of all values underneath.
Meaning the selected value does not remains in the field, instead it shows the default settings the way it shows up in a form whenever user opens the form on web? Other field values remains in the field, after user makes a selection from a dropdown list but only for one value1, it does not remains in. There is no security problem, there is no field limit problem. I tried creating a new document for that dblookup but is still same. Any idea what is wrong?
MS
