Dear All,
How can i extract a body field content via lotusscript in separate fields.
For example:
FirstName TEST1
Surname TESTxxx
Address Address1xxx
Countries GREECE
The values from the second column for each row starts from the same position.
I want to extract the above values from the second column to separate fields in a different form.
I would appreciate it if you could send a sample LS script.
Thanks in advance,
Nick
Subject: Extract body field
I created a form with only one Body field in it and a button.I pasted in this text:
FirstName + tab + TEST1 + newline
Surname + tab + TESTxxx + newline
Address + tab + Address1xxx + newline
Countries+ tab + GREECE
I saved the document.
Then I did what you should have done, read the help file.
In my button, I have this code:
Dim doc As NotesDocument
Dim rti As NotesRichTextItem
Dim rtnav As NotesRichTextNavigator
Dim rtrange As NotesRichTextRange
Dim iCount As Integer
Dim vSplit As Variant
Set doc = ws.CurrentDocument.Document
Set rti = doc.GetFirstItem("Body")
Set rtnav = rti.CreateNavigator
Set rtrange = rti.CreateRange
If rtnav.FindFirstElement(RTELEM_TYPE_TEXTRUN) Then
Do
iCount = iCount + 1
If iCount = 2 Then
Call rtrange.SetBegin(rtnav)
'-- We now have the 2nd line in our 'range'.
'-- If the 'label' and the value are separated by a tab, all you need is to split.
vSplit = Split(rtrange.TextRun, Chr(9))
Msgbox "The text is: " & vSplit(Ubound(vSplit))
Loop While rtnav.FindNextElement(RTELEM_TYPE_TEXTRUN)
This works with the text above. You will have to change the code to suit your particular needs.
Subject: RE: Extract body field
Thank you very much for your response.I check it and i reply
