External Outlook Calendar Invitation for teams meeting does not show anything in body field
Hello again,
we receive from outside some outlook calendar invitation for a teams-meeting. The body-field is not filled or with some odd signs. If the sender sends a "normal" e-mail all links are clickable and there is no problem to participate. We use Domino 12.0. 2 FP3 on our SMTP-Mail-Gateway-Server and on the Server were the mail-dbs are stored. The clients are R12.0.2 FP 2 / 3 with templates form V 11 and V12.
If i look in the source-view of the document, you see the vcard tags with all information. The describtion tag has the links inside but there are some wrong sign allthoough it is utf-8.
Content-Type: text/calendar; method="REQUEST"; charset="utf-8"
BEGIN:VCALENDAR
METHOD:REQUEST
DESCRIPTION;LANGUAGE=de-DE:Sehr geehrte Damen und Herren\,\n\nwie vereinbar
t laden wir Sie hiermit zur nächsten Sitzung...
STATUS:CONFIRMED
SEQUENCE:2
LOCATION;LANGUAGE=de-DE:Microsoft Teams-Besprechung
If we copy the text inside the VCalendar-Tags into a new text-file with the extension ical. A double-click opens these invititation in the notes client with the same result.
I found nothing to corner the problem.
Any hints where to search?
Thank you and Regards
Harald
Hello Harald,
Please refer to the below links and see by setting the below ini on the server helps.
IcalReadXAltDesk=0
ICAL_FORCEADD_XALTDESC=0
https://support.hcl-software.com/csm?id=kb_article&sysparm_article=KB0092071
https://support.hcl-software.com/csm?id=kb_article&sysparm_article=KB0095654
https://support.hcl-software.com/community?id=community_question&sys_id=02025d2d1bdbfcd0a2f48661cd4bcbf7&anchor=answer_07cb1475dbaa095055f38d6d139619ae&view_source=searchResult
Thank you
Regards
Shrikant J
Hello Shrikant,
thank you for the links. I will give it a try, but in both knowledgebase arcticle it is mentioned, that it should be fixed in our Domino-Server-Version 12.0.2 FP3.
I will keep you up.
Regards
Harald
