Extension Manager Problem
Hi!
I’m trying to implement an Extension Manager dll and am having a major issue with the EM_NSFNOTEOPENEXTENDED call back function. Basically i cant get a handle to the Note that is being opened - when ever i make a check against it being a NULLHANDLE it fails.
Here’s a bit of a snippet of my code …
case EM_NSFNOTEOPENEXTENDED:
ap = pExRecord->Ap;
hDB = VARARG_GET (ap, HANDLE);
note_id = VARARG_GET (ap, NOTEID);
Flags = VARARG_GET (ap, WORD);
hNote = VARARG_GET (ap, HANDLE); /* the note */
if (hNote == NULLHANDLE) {
goto Exit0
It will ALWAYS fail at the hNote == NULLHANDLE line (well actually that line will always return TRUE, which in the case of my code consider a fail)
I’m tearing my hair out because that basically means i can never get any info from the NOTE - which obviosly i want to do.
Any help would be awesome
S
Subject: Extension Manager Problem
i’m not really sure about that, but:
did you register EM_BEFORE? hNote should be NULLHANDLE here i think.
next: did you check Struct Alignment? it has to be set to 1. have a look in c-api userguide and follow all commendations.
depending on how you include notes header files this sometimes comes automatically into module-focus, but there’s a good chance it doesn’t.
(see “#pragma pack(1)” in global.h)
Markus Seitz
markus.seitz@icodex.com
Subject: RE: Extension Manager Problem
Thanks Markus,
I’ve tried both EM_BEFORE and EM_AFTER both give me the same issue.
Will look into the Struct Allignment.
Thanks again
S
