We just recently upgraded from Notes 5 to 6. I’ve encountered a problem when manually exporting documents by using the File-Export tool from the menu bar. In Notes 5, this worked fine. I was able to export all the documents I wanted to 1-2-3 or a text file. On the new 6 server, it will only let me export anything under 200 documents. If I select more than 200, the exported file is blank. There is also a 200 doc limit using the new copy as table feature.
Question - Is there a setting on the 6 server that limits the number of ducuments that can be exported? If not, what could be the problem?
Bobby Weir
