Hello,I get the error above when trying to open a document from a view in the web. The view is autmatically created by notes. The only difference I can see to other views is that inside this view are response documents(without their main doc). Show response documents in a hierarchy is not checked. Any hints ?
Martin
Subject: Entry not found in index with response documents in web
The problem is almost certainly not with the view, but with the documents/forms.
There is probably a dblookup/dbcolumn in the form with poor error handling.
Subject: RE: Entry not found in index with response documents in web
Thanx Kenneth,that was the solution
