I have a strange problem after updating clients from R5 to R6.5.3. After updating to R6.5.3 softdeletion ist autpomatic enabled with 48 hours. Some clients work well. When documents are deleted, they are stored in der trash folder. But some clients work diferent. When documents are deleted, they can be found in the trash folder. After closing the mailfile the trash folder is empty. In some other clients, when they delete 10 documents only 5 documents are stored in the trash folder. The other documents are gone.Please help me !
Subject: empty trash problem after update R5 to R6.5.3 - SOLUTION
Please see my posting here for a solution:
Titled:
SOLUTION: Trash folder being emptied unexpectedly and not restoring
Regards,
Richard Kewish
We have the same exact problem in our environment. We are running Domino 6.5.3 fp1on two clustered aix 5.2 servers. As you explain in some of the databases the trash
is working perfectly fine in other cases some
get no trash and others periodically the trash
gets only some of the documents. We have a sev 1 opened with IBM on this since January
Subject: RE: empty trash problem after update R5 to R6.5.3
Hi Eric,
we solved the problem. Or better, we have a workarround. The information about softdeletion is stored in the calander profile of the mailfile. This entry has to be refreshed after updating the mailfile to R6. If the administrator change the entry from 48 hours (standard) to e.g. 96 houres everything works fine !
Another possible Solution:
The system store the 48 h in the calenderprofile - thats right.
But changes will not automaticly stored in the profile! The user must open the Tools - Preferences and store this again. Then the profile will changed.
VERY STRANGE!!!
Titled:
Regards,
Richard Kewish
