Embedded view to other db with using templates
So let me get this straight. To access a view into another db I bookmark it in the designer. I then embed the view I want in the template I’m working on, now here’s the rub. I create 2 versions of this database one is live and the other is test, how on earth do I make the test version’s embedded view access the test version’s db???
Subject: Embedded view to other db with using templates
Hi Jason,
I have the same problem and I didn’t found a solution. It seems to me that we have to recreate everytime the link between the database and the other one containing the view to be embedded.
Regards
Willette Jean-Michel
