Embedded outline entry doesn'y keep focus
I have an application that has an outline embedded in a page and that page is then used in a navigation frameset. The problem I am having is that when I click on an item that points to a view it should retain focus so I can see my current selection. It appears to work for most views but not personal views. If I click the item twice it does then retain focus. I have searched the forum and found a reference to this prob occuring in R5 but was fixed in 5.09.
I can’t find any reference to this problem happening with R6. Is this a known problem with R6? Seems strange that something that was fixed in R5 reappears in R6.
Regards,
Richard
Subject: Embedded outline entry doesn’y keep focus
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/4d79656efe8877a08525709700471307?OpenDocument
