Edit Button not working. Very very very strange problem. Need expert advise
Hello All,
   User is complaining that in few documents the edit button doesn't work. If anyone whose name is mentioned in the Authors field including me(I have designer access) hits the Edit button, there is no response.
However, if i copy and paste the document and hit Edit from within the copied document, its editable.
Strangely i am not able to delete the original document from database too(Yes! i have access to delete the document) . It give me an error “Memory allocation request exceeded 65,000 bytes”.
Please comment…
Subject: Edit Button not working. Very very very strange problem. Need expert advise.
If in use, try disabling document data compression. It has worked for the user below.
http://www-10.lotus.com/ldd/nd8forum.nsf/DateAllFlatWeb/050da6d6764790968525755200728cad?OpenDocument
