EasySync 4.2.3 upgrade problem with Pocket PC
An EasySync 4.2.2 user is trying to upgrade to 4.2.3, using a Dell Axim (Pocket PC). The installation process wants to upgrade software in ROM on the Axim, so it fails. Any suggestions?
Subject: EasySync 4.2.3 upgrade problem with Pocket PC
Switch to Commontime mNotes! You will never have upgrade issues anymore. This is the only PDA Notes client that works truly in Notes replication mode (as opposed to “sync” ;-))
Good luck!
http://www.commontime.com
