Easy Sync Pro and smart phones
Okay- I have spent an hour out there trying to figure out what smart phone to move to- has to connect to Lotus Notes via Easy Sync Pro- Verizon. Information is sketchy at best- if you bought a smart phone based on reviews, you wouldn’t buy one. Any one have any winning stories? What phone? My Treo is dieing and it appears to be time. :frowning: BTW, the IBM info on Easy Sync pro says it works with Palm OS, but says nothing of Palm’s current OS- WebOS, so, I’m guessing it doesn’t work with it.
