I’ve just installed Easy Sync Pro 4.2.1 on to a machine which previously used Palm HotSync and Palm Desktop.
Sync’ing with Notes works fine. But, after the Easy Sync Pro has finished the Palm Hot Sync continues to sync for about ~10 mins, although It is not updating the palm desktop.
I’ve played around with all the sync settings in both Easy Sync and Hot sync to no avail. Exiting the Palm Hot sync program (as recommended in the Easy Sync Help) does not help since Easy Sync Pro just restarts it.
Does any one know how to speed up the Sync.
Thanks In Advance.
