We just upgraded our Lotus infrastructure from R4.6 to R6.5 and are experiencing strange problems with DST settings and calendar entries. For historical reasons with R4.6 the entire system was set not to observe DST. In order to avoid problems with existing calendar entries, at migration time we decided to keep the same settings on R6.5 clients until end of Summer, i.e., setting the location to “don’t use OS settings” and “do not observe DST”. Notice that the client OS and the Domino server are observing DST. The latter causes mails to be timestamped one hour later, we know that…
Now to our problem: After starting Windows and Notes on a client everything works fine during a couple of hours. But after some time the same calender entries are off by one hour, as if the client would suddenly observe DST. To make things worse, neither location entries, nor NOTES.INI params have changed.
Does anybody have an explaination for this? Is there any known combination of settings that forces the Notes client to ignore DST?
Many thanks, Enrico
