Hi All,I installed Domino on RedHat Linux ES. Domino could not open the HTTP port. I tried changing the port no. to 8080,81 but still it didn’t open.When I check the tasks (sh ta) it says only
HTTP Server : Initializing
Please help…
Thanks,
Buwaneka
ps: Apache is not installed on the Linux machine.
Subject: Domino Web Engine does not open the HTTP port
Check to see if you already have an http daemon running, such as Apache.
Do the following:
ps -ef | grep http
and look at the results…
if you see an http server running other than Domino you should deactivate.
/etc/init.d/httpd stop
