I have a problem with a web service on Domino sending a binary attachment in base64.
I have this scenario:
My external provider created a web service using Appache Axis. They generated WSDL from Java classes and gave me this WSDL file. I imported this WSDL into Domino WS consumer (Java) using DDE. Everything fine so far.
But the generated SQAP messages are rubbish.
The WSDL says:
<xs:element name=“messageAttachments” type=“xs:base64Binary” />
In DDE Java WS consumer it is represented by
private byte messageAttachments;
I expect the SOAP meassage to be something like this:
/9j/4AAQSkZJRgABAQAAAQABAAD…
But Domino sends this:
77
106
65
120
This causes an error and nothing is received at the other end…
There are several forum posts about this issue but no solution…
http://www.mail-archive.com/axis-dev@ws.apache.org/msg37279.html
http://markmail.org/message/374oierfppqxbye2
It looks like a bug in Apache Axis 1.x which is built in Domino ![]()
Hope IBM will get rid off Axis 1.x and integrate Axis2.
Any idea for workaround?
Thank you,
Tomas.
